Date/Time: Tue, 11 Mar 2025 17:30:53 +0000
Live data feed
View Count: 506
[2022-05-02 07:52:08] |
User314612 - Posts: 1 |
Hi, My sierra package services are active and the subscription has been paid for, however I am unable to access live data for the exchanges. Kindly look into this as this is a recurring issue. Regards |
[2022-05-02 09:37:21] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
