Date/Time: Sun, 27 Sep 2026 11:04:45 +0000
Volume Profile inconsistencies between brokers
View Count: 939
| [2022-05-01 18:35:41] |
| Giles Troulan - Posts: 3 |
Hi Sierra, I am in a trading group and recently we were comparing Volume profile levels for the ES and noticed that one persons levels were 3-4pts lower than the rest of us for all their HVN and LVN's. We were comparing multiday day VP going back from early 2021 to present. This seemed quite unusual as Volume profile should be a definitive number. Everyone was using Sierra Denali data. The person who we noticed uses AMP futures as a broker and CQG for order placement. I use Stage 5, Denali and Teton. We've checked the chart and study settings are all the same. Can you any reason that the other guys levels would be different to the rest of the group? Thanks for any help. GT |
| [2022-05-01 22:22:24] |
Refer to: Volume By Price Study: Volume Profile Differences If all of the Chart Settings and Study Settings are identical, then the problem must have to do with the underlying data in the chart. In which case re-downloading the data would be the thing to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
