Date/Time: Wed, 12 Mar 2025 05:37:51 +0000
Missing Data
View Count: 815
[2022-05-01 18:04:46]
User404701 - Posts: 7
Hi, I had been an issue where my charts are missing data for several months. For the chart, I have start date = 2022-01-09 and Days to Load Intraday = 480. it shows data from 08/24/2021 till 9-9-21. Then it starts from 03/10/2022. Missing in between. Same problem with other charts as well. I tried deleting and reloading. Also, I did recently upgrade to the latest version but no change. Version - 2383 and revision - 41758. This is for MESM22 symbol.
[2022-05-01 18:06:03]
You need to use the Denali Exchange Data Feed (you are already on a service package which includes this) and activate the exchanges that you require here:
After that is done, refer to the instructions here to fully re-download data for contract months:
[2022-05-05 04:25:36]
I am using CQG and have the CME data feed activated from AMP. How should I activate Denali without paying twice for the CME?
[2022-05-05 05:59:37]
You need to cancel market data through your broker. You do not require it. And then you can activate the exchange you require on the Denali data feed here:
Date Time Of Last Edit: 2022-05-05 06:00:07
