Date/Time: Tue, 11 Mar 2025 17:35:01 +0000
CME Activation
View Count: 442
[2022-05-01 16:57:18] |
Taryn - Posts: 28 |
Hi, I dont have a futures trading account but I have paid for the sierra charts denali package. If I pay the $122 for the option of users who dont have a trading account, will my services be activated and I can get access to real time data. Thank you |
[2022-05-01 17:13:05] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-01 20:17:23] |
Taryn - Posts: 28 |
Hi I need the data for currency futures oon cme. So if I paid $122 which is for professionals and users without a trading account, would I get access to real time live data? Thanks |
[2022-05-01 22:24:53] |
Yes you would. But also have a look at this option: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
