Date/Time: Tue, 26 Nov 2024 09:49:02 +0000
[User Discussion] - ZigZag Hi/Low Trendline issue
View Count: 1502
[2014-04-26 14:58:42]
User31737 - Posts: 73
hi I am trying to run a ZZ H/L Trendline study on Cumulative delta bars(volume) The issue I am having is when the Cumulative Delta is a negative value - the ZZ TL study does not draw a trend line on a negative number high, only on the lows . The stock ZZ study does not have this issue, it will see a negative value swing hi correctly. Is there a way to fix this?
Date Time Of Last Edit: 2014-04-26 16:06:52
[2014-04-26 17:29:55]
A picture helps -- There should be a white horizontal line at the high in each of the red circled ares. However, since the Cumulative delta is negative number, it is not drawing the line.
Not an issue when the cum delta is positive value. It draws the white horizontal lines at the highs and lows
Date Time Of Last Edit: 2014-05-01 14:02:42
imageZZcumTL.PNG / V - Attached On 2014-04-26 17:29:16 UTC - Size: 26.42 KB - 586 views
[2014-04-27 13:20:08]
Does anyone know, seeing as this has been tagged as a user discussion, who created the zigzag high low trendline indicator? perhaps I could message them and get this fixed.
[2014-04-29 15:38:47]
Anyone know the originator of this study?
