Date/Time: Tue, 11 Mar 2025 17:44:53 +0000
Charts in Chartbook Reverting to 6 Tick Range After Updating SC
View Count: 460
[2022-04-30 15:57:47]
cmet - Posts: 676
Version 2390
I updated to this version and opened up my Chart Book as usual but the 2 minute chart that was in that chartbook changed to a 6 tick range bar.
Everytime I try to change it back to a 2 minute, it simply reverts back to a six tick. Also, if I copy any chart from that chartbook and try to change it to a 2 minute, it reverts back - not the chart speed that originally copied but to a 6 tick range chart.
I can create a new intraday 2 minute chart but as soon as I add a study, it reverts back to a 6 tick range chart.
Update: Rolled back to 2386 and the problem is still present when trying to change the 6 tick to a 2 minute. However, I'm able to create a new 2 minute chart and add studies without it reverting.
From what I can tell, this seems to only affect charts that are confined within the main Sierrachart window (tabbed in the bottom of the interface). Free floating charts are not affected.
Strange behavior.
Date Time Of Last Edit: 2022-04-30 17:49:12
[2022-05-02 14:26:47]
John - SC Support - Posts: 38580
Refer to the following for the issue you are having:
Unable to Change the Bar Time Period for Charts
