Date/Time: Tue, 11 Mar 2025 17:37:54 +0000
[Programming Help] - Copy price from the chart
View Count: 601
[2022-04-29 23:33:32] |
User82995 - Posts: 17 |
I would like to know if I can copy in a faster way the price or the value Y from the COMPACT TOOL VALUE. What I want is to make a click in the chart and get the price from that place. Thanks |
[2022-04-30 08:40:18] |
Do you mean copy it to the system clipboard? ACSIL has access to this price: ACSIL Interface Members - Variables and Arrays: sc.ActiveToolYValue Information about ACSIL: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-30 08:40:34
[2022-05-01 16:36:46] |
Yes. I want to copy to clipboard
