Date/Time: Sat, 19 Sep 2026 04:45:05 +0000
MACD histogram bars spacing changes when I zoom in/out - can we set to fix?
View Count: 875
| [2022-04-29 18:44:37] |
| JBTFD - Posts: 39 |
Hi, I have the width of my MACD histogram bars set in the options, however whenever I zoom in/out on the chart with my mouse scroll, the bars get squished (when zoomed in) or theres huge gaps between them (when I zoom out). Is there a way to force the bars to always be proportionate to each other when I'm zooming in/out? Here's what I mean in a photo: https://ibb.co/NKVt9jH The left is when I zoom out, the middle is when its on default (which looks good), and the right is when I zoom in and the bars get squished. On my other platforms when I zoom in/out the bars change proportionally so they never look squished or spread out with gaps in between. Thanks! |
| [2022-04-29 21:18:31] |
| John - SC Support - Posts: 47939 |
The width of the bars is set in the Subgraph settings for the Width. You can manually change this, but it does not adjust automatically. Refer to the information for this setting here: Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
