Date/Time: Fri, 02 Oct 2026 18:21:02 +0000
Error Connecting to Data or Trading Service From within Sierra C
View Count: 781
[2022-04-29 16:02:39]
Vanigan - Posts: 3
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=63860
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2022-04-29 10:16:13.130
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2022-04-29 10:16:13.130
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:16:13.130
Reading Internal Order ID file. | 2022-04-29 10:16:13.277
Reading Trade Orders file. | 2022-04-29 10:16:13.539
Reading Trade Positions file. | 2022-04-29 10:16:13.540
Reading Trade Account Data files. | 2022-04-29 10:16:13.541
Software version: 2390 64-bit | 2022-04-29 10:16:13.607
Safe Mode enabled | 2022-04-29 10:16:13.607
Primary Thread ID: 5776 | 2022-04-29 10:16:13.607
Usage end date: 2022-05-22 | 2022-04-29 10:16:13.607
Enabled for: Advanced Features 2. | 2022-04-29 10:16:13.607
Enabled for: Sierra Chart Historical Data Service. | 2022-04-29 10:16:13.607
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-04-29 10:16:13.607
Enabled for: Delayed Denali Exchange Data Feed. | 2022-04-29 10:16:13.607
Enabled for exchange2: fairx_exchange.data | 2022-04-29 10:16:13.607
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-04-29 10:16:13.607
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-04-29 10:16:13.607
Custom symbol settings values: enabled | 2022-04-29 10:16:13.607
Chart Update Interval: 500 | 2022-04-29 10:16:13.607
Intraday Data Storage Time Unit: 0 | 2022-04-29 10:16:13.607
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-04-29 10:16:13.607
2022-04-29 14:16:13 Local computer time in UTC | 2022-04-29 10:16:13.607
2022-04-29 10:16:13 Local computer time in SC Time Zone | 2022-04-29 10:16:13.607
2022-04-29 14:16:10 Server time in UTC | 2022-04-29 10:16:13.607
Local computer UTC time and Server UTC time difference: 2 seconds. | 2022-04-29 10:16:13.607
Program path: C:\SierraChart\ | 2022-04-29 10:16:13.607
Data Files path: C:\SierraChart\Data\ | 2022-04-29 10:16:13.607
OS Version Number: 10.0 | 2022-04-29 10:16:13.608
Locale Setting: C | 2022-04-29 10:16:13.608
DLLs: UserContributedStudies_64.dll | 2022-04-29 10:16:13.608
Allowed protected custom studies: | 2022-04-29 10:16:13.608
Crash reporter started: true | 2022-04-29 10:16:13.608
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2022-04-29 10:16:13.647
Received 5 login tokens. | 2022-04-29 10:16:13.754
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-04-29 10:16:13.813
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:16:13.823
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-04-29 10:16:13.823
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2022-04-29 10:16:14.062
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2022-04-29 10:16:14.063
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:16:14.063
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2022-04-29 10:16:14.063
Symbol settings MD5 received. Request ID: 1. | 2022-04-29 10:16:15.015
Requested symbol settings for service code rithmic_v2.trading. Request ID: 2. | 2022-04-29 10:16:15.015
Symbol settings received. Request ID: 2. | 2022-04-29 10:16:16.317
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:19.761
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:19.764
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:19.764
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:19.764
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:19.771
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:19.771
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:19.771
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:23.773
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:23.777
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:23.777
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:23.777
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:23.790
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:23.790
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:23.790
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:27.798
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:27.801
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:27.801
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:27.801
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:27.814
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:27.814
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:27.814
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:31.807
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:31.811
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:31.811
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:31.811
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:31.820
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:31.820
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:31.820
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:35.819
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:35.822
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:35.822
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:35.822
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:35.836
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:35.836
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:35.836
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:39.852
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:39.861
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:39.861
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:39.861
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:39.883
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:39.884
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:39.884
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:43.877
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:43.881
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:43.881
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:43.881
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:43.895
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:43.895
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:43.895
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:47.886
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:47.895
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:47.895
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:47.895
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:47.912
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:47.912
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:47.913
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:51.920
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:51.925
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:51.925
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:51.925
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:51.937
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:51.938
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:51.938
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:55.941
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:55.945
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:55.945
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:55.945
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:55.962
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:55.962
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:55.962
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:16:59.960
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:16:59.965
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:16:59.965
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:59.965
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:16:59.979
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:16:59.979
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:16:59.979
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:03.981
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:03.984
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:03.984
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:03.984
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:03.996
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:03.996
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:03.996
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:08.002
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:08.006
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:08.006
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:08.006
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:08.012
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:08.012
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:08.012
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:12.011
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:12.015
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:12.015
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:12.015
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:12.038
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:12.038
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:12.038
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:16.051
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:16.056
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:16.056
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:16.056
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:16.067
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:16.068
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:16.068
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:17:18.376
The message log has been sent to support. | 2022-04-29 10:17:18.376 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2022-04-29 10:17:18.376
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2022-04-29 10:17:18.376
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2022-04-29 10:17:18.737
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2022-04-29 10:17:18.977
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-04-29 10:17:18.977
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:17:18.987
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-04-29 10:17:18.987
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:20.067
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:20.072
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:20.072
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:20.072
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:20.095
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:20.095
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:20.095
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:24.094
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:24.099
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:24.099
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:24.099
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:24.104
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:24.104
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:24.104
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:28.114
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:28.118
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:28.118
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:28.118
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:28.130
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:28.130
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:28.130
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:32.137
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:32.141
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:32.141
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:32.141
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:32.146
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:32.146
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:32.146
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:36.153
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:36.157
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:36.157
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:36.157
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:36.162
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:36.162
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:36.162
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:40.167
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:40.171
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:40.171
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:40.171
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:40.184
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:40.184
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:40.184
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:44.184
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:44.190
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:44.190
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:44.190
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:44.193
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:44.193
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:44.193
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:48.193
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:48.197
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:48.197
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:48.197
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:48.220
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:48.220
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:48.220
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:52.221
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:52.225
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:52.225
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:52.225
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:52.237
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:52.237
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:52.237
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:17:56.229
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:17:56.232
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:17:56.232
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:56.232
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:17:56.246
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:17:56.246
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:17:56.246
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:00.247
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:00.253
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:00.253
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:00.253
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:00.267
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:00.267
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:00.267
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:04.265
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:04.268
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:04.268
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:04.268
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:04.282
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:04.282
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:04.282
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:08.274
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:08.279
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:08.279
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:08.279
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:08.291
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:08.291
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:08.291
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:12.294
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:12.298
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:12.298
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:12.298
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:12.319
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:12.319
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:12.319
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:16.317
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:16.321
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:16.321
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:16.321
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:16.334
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:16.334
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:16.334
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:20.339
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:20.344
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:20.344
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:20.344
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:20.353
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:20.353
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:20.353
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:24.359
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:24.364
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:24.364
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:24.364
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:24.375
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:24.375
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:24.375
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:28.368
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:28.373
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:28.373
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:28.373
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:28.385
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:28.385
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:28.385
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:32.393
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:32.400
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:32.400
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:32.400
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:32.413
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:32.413
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:32.413
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:36.413
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:36.416
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:36.416
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:36.416
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:36.428
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:36.428
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:36.428
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:40.429
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:40.433
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:40.433
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:40.433
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:40.446
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:40.446
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:40.446
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:44.461
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:44.465
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:44.465
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:44.465
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:44.479
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:44.479
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:44.479
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:48.479
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:48.484
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:48.484
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:48.484
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:48.496
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:48.496
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:48.496
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:52.497
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:52.501
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:52.501
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:52.501
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:52.513
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:52.514
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:52.514
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:18:56.508
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:18:56.512
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:18:56.512
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:56.512
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:18:56.520
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:18:56.520
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:18:56.520
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:00.528
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:00.532
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:00.532
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:00.532
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:00.553
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:00.553
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:00.553
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:04.552
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:04.555
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:04.555
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:04.555
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:04.568
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:04.569
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:04.569
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:08.568
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:08.572
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:08.572
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:08.572
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:08.584
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:08.585
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:08.585
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:12.590
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:12.595
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:12.595
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:12.595
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:12.605
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:12.605
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:12.605
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:16.603
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:16.608
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:16.608
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:16.608
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:16.620
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:16.620
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:16.620
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:20.613
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:20.617
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:20.617
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:20.617
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:20.630
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:20.630
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:20.630
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:24.630
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:24.634
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:24.634
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:24.634
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:24.647
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:24.648
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:24.648
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:28.648
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:28.652
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:28.652
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:28.652
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:28.666
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:28.666
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:28.666
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:32.662
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:32.665
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:32.665
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:32.665
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:32.679
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:32.679
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:32.679
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:19:36.685
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:19:36.689
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:19:36.689
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:36.689
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:19:36.702
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:19:36.702
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:19:36.702
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:20:06.677
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-04-29 10:20:06.678
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:20:06.678
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:20:07.168
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-04-29 10:20:07.169
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:20:07.170
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-04-29 10:20:07.170
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:21:36.702
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:21:36.706
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:21:36.706
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:21:36.706
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:21:36.720
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:21:36.720
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:21:36.720
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:22:06.706
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 32768 | 2022-04-29 10:22:06.706
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:22:06.706
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:22:07.196
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call. | 2022-04-29 10:22:07.198
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:22:07.198
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed. | 2022-04-29 10:22:07.198
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:23:36.709
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:23:36.713
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:23:36.713
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:23:36.713
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:23:36.737
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:23:36.737
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:23:36.737
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:24:06.707
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | New receive buffer size: 32768 | 2022-04-29 10:24:06.707
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:24:06.707
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:24:07.197
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | CloseSocket call. | 2022-04-29 10:24:07.199
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:24:07.199
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (1) | Closed. | 2022-04-29 10:24:07.199
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:25:36.729
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:25:36.732
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:25:36.732
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:25:36.732
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:25:36.746
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:25:36.746
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:25:36.746
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:26:06.729
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | New receive buffer size: 32768 | 2022-04-29 10:26:06.730
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:26:06.730
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:26:07.263
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | CloseSocket call. | 2022-04-29 10:26:07.265
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:26:07.265
HTTPS connection ID:5 to www.rithmic.com:443 for request ID:5 (1) | Closed. | 2022-04-29 10:26:07.265
Rithmic Direct - DTC | Using server connection: | 2022-04-29 10:27:36.372
Rithmic Direct - DTC | Remote address is not set. | 2022-04-29 10:27:36.376
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-04-29 10:27:36.376
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:27:36.376
DTC Client socket (0) | CloseSocket call. | 2022-04-29 10:27:36.381
Rithmic Direct - DTC | Disconnected. | 2022-04-29 10:27:36.381
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-04-29 10:27:36.381
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Creating socket. Using TLS 1.2. | 2022-04-29 10:28:06.365
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | New receive buffer size: 32768 | 2022-04-29 10:28:06.366
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Connecting to IP: 38.79.0.89. | 2022-04-29 10:28:06.366
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Socket gracefully closed by remote side. | 2022-04-29 10:28:06.857
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | CloseSocket call. | 2022-04-29 10:28:06.858
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-04-29 10:28:06.858
HTTPS connection ID:6 to www.rithmic.com:443 for request ID:6 (1) | Closed. | 2022-04-29 10:28:06.858
[2022-04-29 16:53:50]
Follow through the instructions here:
Rithmic Trading Platform Service: Setup Instructions
