Date/Time: Tue, 11 Mar 2025 16:47:50 +0000
2388 : date and time disappearing from horizontal axis....
View Count: 537
[2022-04-29 06:47:48] |
User877753 - Posts: 152 |
Both intraday and historical charts. Thanks for your help. |
[2022-04-29 06:57:14] |
Back to 2386 : nothing on horizontal axis. Everything worked fine until 2388 update a moment ago. I'm lost here.... Any idea ? |
[2022-04-29 07:37:33] |
I worked on another instance of SC I use with another data / service : version 2350 is fine version 2386 is fine version 2389 : all time is lost on horizontal axis.... see screesnshots attached Date Time Of Last Edit: 2022-04-29 07:38:27
[2022-04-29 08:00:12] |
For me, Chart Time Scale Text Colors had turned Black (in Graphing Settings - Global) see Price and Time text changed colors | Post: 305271 |
[2022-04-29 09:09:30] |
Check these color settings in Graphics Settings: Chart Text Chart Values Scale Text Color Time Scale Text Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-29 09:09:37
