Date/Time: Tue, 11 Mar 2025 17:03:41 +0000
Multiple lines on crosshair
View Count: 427
[2022-04-29 01:33:47] |
ssangha84 - Posts: 126 |
Hello, is there any way to have my chart value tool crosshair have 2 parallel lines? I want to use this so I would be able to quickly see where a 20 tick stop would be from my main cursor where I would enter. Thanks.
[2022-04-29 10:14:54] |
No, this is definitely not supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-29 10:15:00
