Date/Time: Tue, 29 Sep 2026 02:07:46 +0000
Flatten Positions When Loss Rules Met Function Not Working
View Count: 1023
| [2022-04-28 20:11:24] |
| User643426 - Posts: 144 |
In Global Profit Loss Management, I have the "Flatten Position When Loss Rules Met"checked and my Loss Trigger is "-500.00." Trigger date was set for today "4/28/2022" and under status it says "Positions Flattened for today because daily Loss Met. Feature Disabled until next trading day in Sierra Chart." However, I was still able to trade today past my trigger amount of -$500. I'm trading the MESM22 Micro using the US.EPM22 E-Mini Symbol for order flow. I would like it to lock me out of trading and prevent me from taking any more trades when the Loss Trigger is met. Thank you.
| [2022-05-09 03:38:57] |
Yes there is no locking that occurs by default. It has to be enabled: Global Profit/Loss Management: Lock Trading (Global Settings >> Global Profit/Loss Management) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
