Date/Time: Tue, 11 Mar 2025 16:58:26 +0000
Rithmic
View Count: 434
[2022-04-28 16:26:25] |
Alex Angehrn - Posts: 5 |
Hi, I have done all requested topics. Nonetheless it doesn't work. Data will not downloaded (see attachments). May you say me how to fix it. Best regards, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=63815 |
[2022-04-28 16:37:56] |
The problem is you will have issues and limitations with Rithmic historical data and you need to use the Denali data feed instead of Rithmic market data. You can still trade through Rithmic. Full details are here: Rithmic Trading Platform Service: Rithmic Support Policy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-28 16:38:51
