Date/Time: Tue, 06 Oct 2026 23:34:42 +0000
Price and Time text changed colors
View Count: 986
| [2022-04-28 15:13:51] |
| 58LesPaul - Posts: 429 |
I updated SC to 2386 yesterday and my price and time text went to white from black. Not a big deal to change back and IDK if everyone experienced this but just thought you should know.
| [2022-04-28 15:36:31] |
| User829162 - Posts: 31 |
Mine did too on both v2386 and v2387. The "Graphic Chart Settings - Chart" was Checked for "Use Global Graphics..." with both Chart Value Scale Text Color and Chart Time Scale set to Black (White background) and does not work. When I UNCHECK "Use global Settings..." and Apply, then the black text for both time scale and Value Scale
| [2022-04-28 16:19:11] |
Global graphics settings for those were changed to white on mine when I updated so I just changed it back to black.
Date Time Of Last Edit: 2022-04-28 16:19:41
| [2022-04-28 17:31:16] |
On the other hand, My "Global Graphics Setting for Both Scale & Time Scale Text is defaulted to BLACK. They do NOT display as Black, but White. Toggling them did not reset the Text Color with Use Global CHECKED
| [2022-04-29 07:13:20] |
Update to the latest Sierra Chart version: Software Download: Fast Update See if there any further issues. Check the following color settings: Chart Text Chart Values Scale Text Color Time Scale Text Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-04-29 11:17:21] |
v2390 downloaded, issues are Fixed. Thanks for the quick response. SierraCharts is the best...
