Date/Time: Tue, 26 Nov 2024 09:32:09 +0000
Spreadsheet Trading System Question
View Count: 1161
[2014-04-25 19:03:18] |
infpz - Posts: 826 |
I am trying to initiate an Sell order when the RSI reaches 100. However, I would like to have the order sent if the RSI value closes over 100, not as soon as the value of 100 is reached. Can you tell me if this is possible without ASCIL? If so, assuming the RSI value were in Column AA and the 100 Value was in AB, what text would go in the Sell Entry column?
[2014-04-25 19:14:17] |
Set Signal Only on Bar Close (K,M) to Yes. The formula is: =AA3>=100 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-25 19:24:16] |
however if I want to tie the order to the subgraph instead of the specific value 100, it would be better to use the language suggested in the documentation, I assume. thank you
[2014-04-25 19:47:39] |
You can reference the Line column directly.
