Date/Time: Tue, 11 Mar 2025 17:08:35 +0000
Out of order data
View Count: 403
[2022-04-28 00:07:55] |
User573482 - Posts: 6 |
Hello, I'm getting a Out of order historical intraday data. I've deleted and downloaded All data and it's still an issue. Is the next step to delete the 'Data' folder so as to download all data afresh? Thanks, Raja |
[2022-04-28 13:36:02] |
We see you are using Transact. We do not provide support for Transact data. You need to use the Denali Exchange Data Feed for data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
