Date/Time: Tue, 26 Nov 2024 09:38:50 +0000
Modify Text and its alignment for Extending Rectangle Highlight
View Count: 1271
[2014-04-25 18:37:38]
raven2cz - Posts: 4
Hello, how can I set in ACSIL "Modify Text" attribute and uncheck "Labels On Right" for Extending Rectangle Highlight? I'm using s_UseTool component. Thanks for help.
[2014-04-28 15:19:20]
Al SC Developer - Posts: 434
Currently, this can not be done. However, in ver 1129 you will be able to do this with the following lines:
s_UseTool Tool;
Tool.Text = "Text to add";
Tool.TextAlignment = DT_LEFT; // use DT_RIGHT to place on the right
