Date/Time: Tue, 11 Mar 2025 02:33:18 +0000
chart setting difficult to read since the new update
View Count: 461
[2022-04-27 19:18:17]
inusuel - Posts: 10
Since the new update
The option Chart Setting look like the picture included .
It is difficult to know which tab is selected ,
because offen the first title is not the same then the first line
like these tab =
2-data limiting
3-bar period
5-display
9- scale
11- market depth.
12- chart drawing
is it possible to named the tab in the first line ( just below the setting name ) like the tab 1- symbol ( the name of the tab is the same then the name of the first line ( please put a line for a title even if this first line use just for that and have not fucntion except the named of the tab )
it will be heplfull to figure which tab is open tab is open
Thank you
imagechart setting.jpg / V - Attached On 2022-04-27 19:16:57 UTC - Size: 240.75 KB - 138 views
