Date/Time: Tue, 11 Mar 2025 02:32:16 +0000
Add POC and unfinished auction from numbers bar chart to regular tick chart
View Count: 599
[2022-04-27 18:29:26]
User402365 - Posts: 9
I have 2 charts for ES and both are 2000 tick bar charts but one of them has the numbers bar study applied to it. On the numbers bar chart I have the point of control and unfinished auctions highlighted on each bar. Is there a way for me to put something like a dash on my candles on the regular 2000 tick bar chart where the point of control is and the unfinished auctions? Thanks so much.
[2022-04-27 21:08:54]
John - SC Support - Posts: 38547
The information for these can not be pulled out of the Numbers Bars study, as they are not made available in that study.
The Point of Control can be done by using the study Volume Point of Control for Bars. Refer to the following:
For the Unfinished Auction you might be able to put together a Spreadsheet Formula that checks the Bid and Ask volumes at the High or Low of the bar and then you can use that to create a mark of some kind. Refer to the information for how Alerts (which the Spreadsheet Formula uses for its syntax) can access the Volume information here:
Study/Chart Alerts And Scanning: Special Functions
