Date/Time: Tue, 11 Mar 2025 02:13:37 +0000
Chart Drawing Properties
View Count: 498
[2022-04-27 18:07:27]
sandpiper4011 - Posts: 17
Where has the 'Modify Text' been moved to ?? Used when adding a line to a chart and then identifying the line. thanks
[2022-04-27 19:16:51]
JohnR - User831573 - Posts: 319
It is still in the menu.
Right click on line, then in the popup menu, it is near the bottom.
JohnR
imageLine - Modify text.jpg / V - Attached On 2022-04-27 19:16:34 UTC - Size: 73.22 KB - 129 views
[2022-04-27 19:20:31]
You will need to add it to the menu if it is not already there. Instructions:
Chart Drawing Tools: Customizing Chart Drawing Shortcut Menu
