Date/Time: Mon, 21 Apr 2025 23:27:30 +0000
error
View Count: 694
[2022-04-27 16:33:06]
User924526 - Posts: 1
There is a second error message after clicking OK: The configuration file size of 26 bytes is not the 352258 expected bytes to write. The configuration file might be corrupt. Then: The configuration file size of 0 bytes is not the 38 expected bytes to write. The configuration file might be corrupt.
[2022-04-27 16:57:25]
John - SC Support - Posts: 39395
If you have a corrupt configuration file, then you would want to use a backup copy. Refer to the following:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2022-04-29 13:11:48]
SC Support - Posts: 1955
Spoke to User924526, helped with set-up
[2022-04-29 13:47:51]
The correct link for using a backup configuration file is here:
Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File
