Date/Time: Tue, 11 Mar 2025 02:09:36 +0000
Add Market Name To DOM after Removing Title Bar
View Count: 418
[2022-04-27 13:07:46] |
User760864 - Posts: 6 |
After removing the title bar from a DOM, is it possible to have the name of the market listed in the DOM window near where net change is displayed?
![]() Attachment Deleted. |
[2022-04-27 13:34:33] |
There are many fields you can add through this setting: Global Settings Menu: Customize Chart Header - Trade DOM (Global Settings menu) Including the Custom Title Bar name: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-27 13:34:49
