Date/Time: Tue, 11 Mar 2025 16:42:47 +0000
No Market By Order Data in the trading DOM
View Count: 538
[2022-04-27 08:41:11] |
User552328 - Posts: 1 |
Hi I have purchased the 12 - Advanced MBO + Denali Data Feed (Monthly) - 56 USD / Month, and i can' t see the pending orders in the trading Dom Can you help me? Thank you |
![]() Attachment Deleted. |
[2022-04-27 14:06:40] |
John - SC Support - Posts: 38579 |
You need to go through the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* As part of that process, you will select the exchange(s) that you want activated. In order to get the "Pending Orders" you will need to ensure you activate exchange(s) that include Market Depth data. After you have that setup, you will need to go through the setup for the Market by Order data here: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-29 05:23:45] |
Also, Forex symbols do not provide market depth or market by order data. You need to use a futures symbol. You can start by using the Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-29 05:24:00
