Date/Time: Tue, 11 Mar 2025 02:07:32 +0000
select multiple drawings, not through Manage Drawing window
View Count: 543
[2022-04-26 23:13:40]
User815278 - Posts: 13
Hello, I want to select multiple drawings quickly with mouse. The problem with Manage Drawing Window is that I cannot easily delete drawings in a specific area, drawings from the entire chart are mixed together. I googled a bit on this topic, there doesn't seem to be a way to do this, just want to confirm with you.
If this is not possible, would love to have this feature in the future.
Thank you!
[2022-04-27 13:39:42]
John - SC Support - Posts: 38547
The only option available to do close to what you want is to use Tools >> Erase Drawing Mode. This will allow you to select and erase drawings one after another. Refer to the following:
Chart Drawing Tools: Erasing Chart Drawings
