Date/Time: Tue, 11 Mar 2025 02:19:30 +0000
Volume At Price Threshold Alert V2 Study
View Count: 537
[2022-04-26 22:18:09]
Kevin Nitkovszki - Posts: 1
Dear Support Team,
i would have a question to the Volume At Price Threshold Alert V2 Study. I would like to use it to mark Imbalances on the Number Bars Chart with Bid x Ask option.
If im right the study only shows the Imbalances for Bids. For current settings see Img 1 & 2. I would like to see the Imbalances on the Ask side too. I have tried it with a negative Volume Threshold: -1 but I think that it doesnt work.
What should i do to see both sides aswell?
Thank you for your Help!
imageIMG1.PNG / V - Attached On 2022-04-26 22:17:33 UTC - Size: 39.21 KB - 172 views
imageIMG 2.PNG / V - Attached On 2022-04-26 22:17:37 UTC - Size: 57.81 KB - 140 views
[2022-04-27 13:31:58]
John - SC Support - Posts: 38547
You have the right idea. But you need to use 2 different Volume at Price Threshold Alert V2 studies to do both Bid and Ask separately. Refer to the information here (note the last paragraph):
Volume at Price Threshold Alert V2: Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance)
