Date/Time: Tue, 11 Mar 2025 02:24:30 +0000
Tradepro download chart not matching what I have ?
View Count: 463
[2022-04-26 16:10:30] |
Nwankwo - Posts: 10 |
Hi, I am a new user of your software. I downloaded TradePro Chart template as required for my training but the chart and format is not showing the same, which makes difficult and impossible to do my homeworks. How do I resolve the issue. Also, I noticed that "chart setting" template is different from the tutoring template TradePro Acedemy is using. Overall, I need help to be on the same page with TradePro Acedemy templates.
[2022-04-26 16:51:58] |
John - SC Support - Posts: 38547 |
We do not know. If TradePro Academy is supplying you with templates/chartbooks/study collections/etc. and they are not what you are expecting, then you need to ask TradePro Academy about this.
