Date/Time: Tue, 11 Mar 2025 02:02:23 +0000
F5 Chart Menu
View Count: 472
[2022-04-26 10:50:41] |
ImKamil - Posts: 5 |
Hi Support, I have updated the SC to version 2385. Since doing this, I have noticed that my Chart Menu on F5 appears differently to how it was showing before. Previously it was showing as a grey window, this has now changed to sort of a black menu (Picture of this attached with this thread). Is there a way to revert this back to the original menu in grey. I found that to be a lot simplier with Advance Settings 1,2 etc showing at the top. Any help will be really appreciated. Thanks |
[2022-04-26 14:44:26] |
John - SC Support - Posts: 38547 |
Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NewChartSettingsWindow For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
