Date/Time: Tue, 11 Mar 2025 02:19:44 +0000
Trader DOM - Open trade text is not aligned to cell?
View Count: 501
[2022-04-26 00:17:42]
JBTFD - Posts: 34
I'm just dabbling in sim as I'm getting acquainted with SC. Is there an option I didn't check that's causing this?
https://ibb.co/mX5QntN
https://ibb.co/wrvPYWx
As you can see, the red box that shows the current open P/L is not centered on the cell, its kind of floating above. How can I fix this?
Edit: I see that it's because it's not rounding my average entry price (4290.06) that's why it looks like its floating there. Is there anyway to round the average entry price to the nearest tick?
Date Time Of Last Edit: 2022-04-26 05:02:01
[2022-04-26 14:37:30]
John - SC Support - Posts: 38547
The reason why the price is not an even tick is because you must have put in multiple orders rather than one single one. As such, the order line shows the Position Average Price. Refer to the following:
Trading Information Windows: How Average Price for Positions Is Calculated and Used
[2022-04-26 14:53:21]
JBTFD - Posts: 34
Thank you John -- is there a way to make the average price round to the nearest tick, so the last decimal places are always .00, .25, .50, .75?
[2022-04-26 15:08:19]
No, there is no support for this.
