Date/Time: Tue, 11 Mar 2025 01:54:58 +0000
Live Data to Excel
View Count: 1022
[2022-04-25 19:50:21]
SierraTraders - Posts: 69
would it be possible to get live data in excel spreadsheet
with the spreadsheet for trading it does not give any tool bar options
currently using SC Denali
[2022-04-25 21:25:01]
John - SC Support - Posts: 38547
It is not possible to get live data into Excel.
There are two things to you can do to get as close to it as you can.
The first is the Write Bar and Study Data to File. You can then parse the file and update the information into Excel. Refer to the following:
Write Bar and Study Data To File
The other option is to use ACSIL to write a custom study that will give you access to the information. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL)
