Date/Time: Sun, 24 Nov 2024 14:10:04 +0000
SMS Trial Activation
View Count: 724
[2022-04-25 18:11:53]
andreidzu - Posts: 1
I do not receive the SMS code on my phone.
I get the message "{"Result":"Code sent to your mobile number. When received, enter this code in the box below."}", but I don't receive anything on my phone.
The mobile number that I entered is the same as the one on my account.
Could you please help me ? I really want to try the software before making a decision on subscribing.
Thank you!
[2022-04-25 21:02:18]
We have activated the trial for your account.
[2022-07-07 16:09:56]
smanookian - Posts: 1
Same problem here. How to fix this?
[2022-07-07 18:08:49]
smanookian:
[2022-07-10 19:19:23]
User259686 - Posts: 1
hello, I just registered today, but activation via sms did not work, could you help me?
[2022-07-10 20:16:08]
We activated your account.
[2022-07-27 10:10:07]
User390383 - Posts: 1
hello, but activation via sms did not work, could you help me?
[2022-07-27 18:56:58]
User390383:
[2024-05-30 02:56:59]
hoyami4010 - Posts: 1
I have the same problem, please help me to active my account.
Many thanks
[2024-05-30 03:21:17]
Sierra_Chart Engineering - Posts: 17156
Use the Symbols which are available during the trial:
Sierra Chart Trial Account
No activation is required to use these.
Date Time Of Last Edit: 2024-05-30 03:21:28
[2024-05-30 15:15:59]
hoyami4010:
During your trial there are certain symbols which you can use. They are listed here:
Sierra Chart Trial Account: Introduction
Those symbols will work. For full access to all symbols, you need a paid account at this point in time.
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Account Control Panel" on the Sierra Chart software menu.
On the displayed webpage, click on "Activate Services".
Or you can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password if necessary.
2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
Date Time Of Last Edit: 2024-05-30 19:05:05
