Date/Time: Tue, 11 Mar 2025 02:13:54 +0000
Quote Board PnL update when not selected and default PnL format.
View Count: 461
[2022-04-25 16:48:21]
virtualcointrading - Posts: 39
Hello, I have noticed that unless a symbol is selected, I don't see it's OpenPosition P/L being updated.
Also, the Daily P/L is displayed in Points unless I select the symbol, is it possible to change this behavior to always display in ticks?
[2022-04-25 22:54:17]
Sierra_Chart Engineering - Posts: 18738
When you say "a symbol is selected", where are you referring to? Whether it is selected or not in the Quote Board is irrelevant. It changes nothing.
Date Time Of Last Edit: 2022-04-25 22:54:26
[2022-04-26 07:52:52]
Hello Sierra_Chart Engineering
To illustrate what I mean:
SC - Ticks.png: ES is selected P/L is in ticks.
SC - Points.png: UB is selected, ES P/L is now in points.
Other symbols that are not selected don't have any P/L showing.
imageSC - Ticks.png / V - Attached On 2022-04-26 07:46:56 UTC - Size: 47.1 KB - 138 views
imageSC- Points.png / V - Attached On 2022-04-26 07:47:07 UTC - Size: 46.65 KB - 137 views
