Date/Time: Sun, 16 Mar 2025 03:00:47 +0000
Data lag issue
View Count: 585
[2022-04-25 14:42:40]
12VMan - Posts: 45
Sierra has a severe lag for me today. I've manually deleted all of the .dly and .scid files and the issue persists. Can you help troubhleshoot?
Thank you
[2022-04-25 14:51:13]
12VMan - Posts: 45
Fyi, I use Denali
[2022-04-25 15:29:23]
Yes, the lag would be 10 minutes in your case.
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
[2022-08-08 13:45:48]
12VMan - Posts: 45
I've connected to my funded account and can see my account balance correctly, but am still receiving delayed data when I reconnect to SC Data - All Services?
Thank you
[2022-08-08 13:52:54]
Sierra_Chart Engineering - Posts: 18796
You need to activate the exchanges that you require here:
