Date/Time: Tue, 11 Mar 2025 01:54:12 +0000
% up or down volume for day
View Count: 458
[2022-04-25 10:25:15] |
User274507 - Posts: 37 |
Hi, Would like to be able to see what % of the volume for a day was up or down volume, is there a way to do this? Would like to ideally view it underneath the data for ES. I added the up/down volume ratio study under a daily ES chart but it wouldn't show any data? thanks, Nick |
[2022-04-25 16:32:31] |
John - SC Support - Posts: 38547 |
Individual trade information is not available on a Daily historical chart. You would need for this to be an Intraday chart in order to get the information you want. Refer to the following for how to do this: Chart Settings: 1 Day Bars (Time Specific Bars) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
