Date/Time: Tue, 11 Mar 2025 02:27:40 +0000
Duplicate Chart Causing Issues
View Count: 501
[2022-04-25 04:08:06]
User148596 - Posts: 217
Hi, I've tried duplicating charts to be used with another symbol by selecting duplicate chart and by selecting find symbol > Duplicate Active Chart. In both cases if I make certain changes to the chart settings in one chart it will change the symbol of the other chart (specifically [Trade and Current Quote Symbol] on Main Settings page). Is there a way to duplicate charts so that doesn't happen or do I have to completely rebuild charts from scratch for each symbol in a chartbook?
[2022-04-25 08:28:58]
User431178 - Posts: 612
Do you have chart linking enabled on the chart that you are duplicating? https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
Definitely not!
Date Time Of Last Edit: 2022-04-25 08:29:17
[2022-04-26 18:57:59]
Yes check to see that Chart Linking is disabled.
[2022-04-26 19:03:21]
Yes, chart linking was the problem. Thanks!
