Date/Time: Tue, 11 Mar 2025 01:24:30 +0000
[User Discussion] - IB T&S data displayed in Time and Sale window is not ordered by timestamp
View Count: 397
[2022-04-25 00:44:06] |
User495091 - Posts: 3 |
IB T&S data displayed in Time and Sale window is not ordered by timestamp. In addition, there are many rows with value 0 in 'Volume' column but value 1 in 'Num Trades' column, as example. |
[2022-04-25 10:58:17] |
What you describe definitely can be the case with Interactive Brokers data. Make sure you are not using true real-time: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TrueRealTimeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
