Date/Time: Tue, 11 Mar 2025 01:21:23 +0000
not able to click enable to change chart bar setting
View Count: 453
[2022-04-24 23:48:25]
laogong2022 - Posts: 3
Hi, when I tried to change chart graphics, I was not able to click enable after I selected candle up fill and candle down color, thanks
imagecandle.JPG / V - Attached On 2022-04-24 23:46:28 UTC - Size: 31.86 KB - 134 views
[2022-04-25 06:08:48]
Tonkadad - Posts: 235
My software responds the same as yours, not sure what enabled is for. I am running ver. 2383. I can change all the colors on candle sticks, I have never needed to click enabled to get the colors to change.
[2022-04-25 15:18:31]
The " Enable" setting is not supported with all graphics items. It is not relevant for Candlestick bar colors. Full documentation for Graphics Settings:
Graphics Settings
