Date/Time: Tue, 11 Mar 2025 01:06:28 +0000
APEX Connection Using Rithmic & IQFeed
View Count: 685
[2022-04-24 19:30:15] |
User234293 - Posts: 2 |
Would it be possible to to get Realtime Data and trade an Apex account using two SC copies using the following process? One copy for APEX Rithmic account and the other copy for IQFeed. Then access the IQFeed data in the trading account using the process shown on this page?> Using Multiple Data and Trading Services at the Same Time
[2022-04-24 20:40:17] |
Yes you can do this. Instructions: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Although it is drastically more simplified and much more reliable and you going to have a much better data feed by using the Denali Exchange Data Feed: Denali Exchange Data Feed: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-24 21:30:43] |
Thank you for your confirmation. Totally understood that Denali would be the easier route. Just trying to save a few $$ since I am already paying for data and exchange fees with APEX and IQFeed. Date Time Of Last Edit: 2022-04-24 21:31:11
