Date/Time: Tue, 11 Mar 2025 17:03:41 +0000
Numbers Bars
View Count: 480
[2022-04-23 23:53:56]
User402365 - Posts: 9
I have two charts side-by-side. Both charts are ES and are 2000 ticks. The first one is a normal bar chart and the second one has the Numbers Bars study. I was curious why the two charts don't match in terms of the time the bar forms, open price, high price, low price and close price. They are close but not exact. Is there a way I can get them to match? Thanks so much.
[2022-04-25 14:24:27]
John - SC Support - Posts: 38580
There must be some difference in the chart settings between the two charts. Otherwise, they should be the same.
Refer to the following regarding ensuring the Session Times are the same:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.8 - Comparing Intraday Chart Bars
One of the easiest ways to resolve this would be to take whichever chart you believe to be the "Correct" one and then duplicate it and set it up the way you want. Your charts should match exactly that way.
[2022-04-29 10:05:26]
Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
