Date/Time: Tue, 11 Mar 2025 01:19:19 +0000
Trial Activation
View Count: 535
[2022-04-23 15:38:12] |
Izeek - Posts: 2 |
Hey, my trial package is not active. Can you please activate it?
[2022-04-23 15:43:25] |
We have temporarily activated your account.
[2022-04-23 15:48:59] |
Izeek - Posts: 2 |
Sorry but I thought the trial was for 15 days?
[2022-04-23 16:49:29] |
You are able to do your own trial activation as documented here: Sierra Chart Trial Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
