Date/Time: Tue, 11 Mar 2025 01:16:02 +0000
Study removed from UserContributed Studies, how do i repoint it to SierraChart Studies_64
View Count: 509
[2022-04-22 21:55:17] |
User752602 - Posts: 9 |
One of the studies I use (ALMA) was removed from the UserContributedstudies.dll a few releases ago and now it's in the default SierraChart Studies_64.dll. How can I point this to it's current location? I know I can just add it and re-type all my inputs and subgraphs, but i'd rather not do that if there's a simple way to point it to the new DLL.
![]() ![]() Attachment Deleted. |
[2022-04-23 09:20:27] |
No there is not an easy way to do this. You need to remove the old study and add the new one. We think this is the study you are referring to: Moving Average - Arnaud Legoux Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-23 09:20:36
