Date/Time: Tue, 11 Mar 2025 02:02:55 +0000
Question: Server side orders and duplicating trades on another instrument
View Count: 447
[2022-04-22 17:17:43] |
Ben A - Posts: 123 |
Hi, Is there a way to add an order on two instruments simultaneously eg NQ and ES at the same time? Also, do you have any routing services currently that support server side orders? Thank you very much indeed, |
[2022-04-22 17:32:23] |
John - SC Support - Posts: 38547 |
Is there a way to add an order on two instruments simultaneously eg NQ and ES at the same time? You would have to put together a custom study to do this. There is not a built-in method for it. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) Also, do you have any routing services currently that support server side orders?
All of the routing services we work with support some form of server side orders. The exact support varies between them. But, for the best support for server side orders, we recommend our Teton Order Routing Service. Refer to the information here: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-24 22:35:14] |
Hi, Apologies needing to follow up... Spoke with AMP and they said they do not have Teton and when I asked what routing that can be provided with server side orders they said 'speak with Sierra Charts' Thanks for the advice. |
[2022-04-25 16:07:29] |
With AMP you would be setup with CQG. Refer to the information at the following link for how server side orders are handled with Sierra Chart and CQG: CQG Trading Platform Service: What is Included For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-25 16:22:04] |
Mmm.. No server side bracket orders. I think it may be time to change broker in that case. Thanks John |
