Date/Time: Tue, 11 Mar 2025 02:31:42 +0000
New User Help with trade window
View Count: 502
[2022-04-22 15:47:40] |
Greg Barrett - Posts: 11 |
When I am i Sim Mode, the trade window snows /the trade account as Sim1. When I am in live mode it says Unset. I can't find any instruction's on this. Also in the trade orders window an trade position window sim appears but no will not show trade account when in live. How do I know My sierra account is connected to my Funded account? I am Using Iron Beam Futures. Where do I find this in table of contents?
[2022-04-22 16:09:31] |
John - SC Support - Posts: 38547 |
You are not connected to your trading account. What order routing service are you using with Iron Beam. Once we know that, then we can point you to the proper instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-22 17:46:38] |
I believe I am supposed to in Teton. Iron Beam set this up.
[2022-04-22 20:07:08] |
Then you need to go through the Setup Instructions for the Teton Order Routing Service starting at Step #6 here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-27 12:45:45] |
Let us know if any further help is needed here.
