Date/Time: Tue, 11 Mar 2025 01:00:43 +0000
[User Discussion] - Help with displaying two TPO profiles side by side (same period and symbol)
View Count: 492
[2022-04-22 13:13:32] |
User111326 - Posts: 17 |
Hi I wanted to display 2 TPO's side by side for the same symbol and period. The second TPO would show split (Letter blocks in own columns). I have searched numerous threads and played around with the TPO settings from the Sierra charts studies reference but can't seem to work this one out. As soon as l add the second TPO profile with the same details as the first l get a blank chart. |
[2022-04-22 14:52:01] |
You need to add the TPO Profile Chart study once to the chart. After that right click on the profile and select: Letters/Blocks in Own Column and Standard Profile. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-22 14:52:10
[2022-04-22 15:04:26] |
Thank you that worked a treat
