Date/Time: Mon, 19 Oct 2026 21:18:41 +0000
[User Discussion] - Buy/Sell Pressure Study Help
View Count: 18212
| [2014-04-24 23:52:24] |
| cmet - Posts: 743 |
Would like to create a simple buy/sell pressure using upticks and downticks but expressed as a percentage. Simple Formula:((Total Upticks - Total DownTicks) / (Total Upticks + Total DownTicks) )* 100 Ideally I would like this to be plotted as a "meter" where 0% would be in the middle with 100% and -100% on the ends. In real time, the dominant color (green for a higher uptick percentage, red for higher downtick percentage) would fill up more of the meter. Here is an image of sentiment meters (these are for FX but pretty much what I'm looking for): http://s30.postimg.org/t4brbi7gh/meters.png Is this (or something similar) possible in SC? |
| [2014-04-25 07:42:20] |
In this formula: ((Total Upticks - Total DownTicks) / (Total Upticks + Total DownTicks) )* 100 What is the time period for these variables? For an individual chart bar? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-04-25 12:07:44] |
| cmet - Posts: 743 |
Time period is pretty much irrelevant since it's using the tick data and would update in real time based on buying/selling activity in a particular product. The readings would just be taken from the chart itself on a tick by tick basis and accumulated over the length of the session. Only other setting needed would be that it starts over at zero from the beginning of the session. A nice implementation of this I've seen is plotted vertically on the left side of the chart like these mockups: Buying Pressure: http://s27.postimg.org/ux18qzklv/meterup.jpg Selling Pressure: http://s4.postimg.org/hgqvemb71/meterdown.jpg Very useful sentiment indicator to help you quickly gauge the underlying pressure in the market in real time. Also, since it's using total ticks on the session, it's not usually jumping around from positive to negative on every single rotation during the day. Date Time Of Last Edit: 2014-04-25 12:16:13
| [2014-04-25 18:04:21] |
This is definitely advanced programming. We cannot provide any specific help with it, but Sierra Chart does have the general capabilities to accomplish this. It is up to you to implement this. You can access the data you need with the Base Data arrays: https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn For the actual drawing, we recommend using the ACSIL drawing tools: https://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-04-25 18:14:58] |
| cmet - Posts: 743 |
Oh, okay. I would think the cummulative net tick formula above was simple. I know more than a few traders at the CBOT who use sentiment indicators like this to trade intraday so am intersted in having it done. Where do I find a programmer who can do something like this? Date Time Of Last Edit: 2014-04-25 18:15:15
| [2014-04-25 23:53:50] |
| crazybears - Posts: 314 |
Hi if you don't have hurry i could try to code it something basic , displayed like a histogram IMHO Total Upticks + Total DownTicks is equal to volume |
| [2014-04-26 01:33:50] |
| cmet - Posts: 743 |
Sure if you can use the exact formula mentioned above where the output is expressed as percentage. Total Upticks + Total DownTicks is not volume though. It's how many times the bid was hit or the offer lifted without regards to the amounts traded. This is really not a complex indicator. The only thing that might be challenging is to get it to display as described above. The vertical "meter" is nice but a horizontal one like those shown in the first image is fine too. Just looking for something that's very clear by just glancing at it. |
| [2014-04-27 20:08:45] |
Hi i made a very basic version . i'm not able to code complex drawings like you posted maybe someone could add more options. http://www.sierrachart.com/image.php?l=1398628229600.png |
| [2014-04-27 20:15:32] |
if you like to have draw on main panel with only text on the left as in picture, you add the study and set Chart region =1 Scale =Independent on Subgraphs tab set Draw style as Subgraph name and value label only set name label and value label to show Horizontal align left edge |
| [2014-04-27 21:37:08] |
| cmet - Posts: 743 |
Hey, thanks Is this based on the formula mentioned above? ((Total Upticks - Total DownTicks) / (Total Upticks + Total DownTicks) )* 100 If so, are those scale numbers percentage based (ie: 9.5 = 95%, -3.0 = -30%)? |
| [2014-04-27 21:57:58] |
i thought that at the start of each day indicator is reset and indicator is calculated accumulated on each new tick , not for each single bar , am i wrong? UpT[Index] = UpT[Index - 1] + sc.UpTickVolume[Index]; DownT[Index] = DownT[Index - 1] + sc.DownTickVolume[Index]; TotUpDownT[Index]=UpT[Index]+DownT[Index]; BuySellMeter[Index] = ((UpT[Index]-DownT[Index])/(TotUpDownT[Index]))*100; |
| [2014-04-27 22:32:39] |
ok i made mistake using up and dow tick volume . make 2 version using sc.BaseData[SC_BIDNT] or sc.NumberOfBidTrades: The array containing the total number of trades at the bid price or lower. For this to work properly, the Intraday Data Storage Time Unit setting in Global Settings >> Data/Trade Service Settings. needs to be 1 Tick. This will also not work on historical data that does not have bid volume. In the case of Tick, Volume, and Range charts, the data in this array may not be correct if Chart >>Chart Settings >> Split Data Records is enabled, unless you are using tick data and the chart is based on Ticks or a Range. If you are using this array in your study function, you must set sc.MaintainAdditionalChartDataArrays to 1 in the sc.SetDefaults code block. sc.BaseData[SC_ASKNT] or sc.NumberOfAskTrades: The array containing the total number of trades at the ask price or higher. For this to work properly, the Intraday Data Storage Time Unit setting in Global Settings >> Data/Trade Service Settings needs to be 1 Tick. This will also not work on historical data that does not have ask volume. In the case of Tick, Volume, and Range charts, the data in this array may not be correct if Chart >>Chart Settings >> Split Data Records is enabled, unless you are using tick data and the chart is based on Ticks or a Range. |
| [2014-04-27 23:06:13] |
| cmet - Posts: 743 |
Not quite what I was looking for. This isn't a volume based calculation. It should never plot above 10 (or 100%) or below -10 (or -100%) I can just use the S&P net tick (NTCK-SP with Rithmic) Thanks though. |
| [2014-04-28 01:42:50] |
| cmet - Posts: 743 |
For comparison purposes, here is the S&P 500 Net Tick for the day session on Friday. You can clearly see that the market was dominated by selling pressure all day without much let up. http://s30.postimg.org/eibyljlox/spnettick_4_25.jpg Would have been easy to get fooled by the 8 point move around 8am to 9am PST if you were only watching price (or even cumulative delta). Net Tick showed almost no buying pressure at all during the upswings. Very useful information intraday. Date Time Of Last Edit: 2014-04-28 01:44:00
| [2014-11-04 20:05:31] |
| jivetrader - Posts: 410 |
i am also interested. has there been any further progress on this? i see that a retail product is available: http://ofetoolbox.kajabi.com/sp/26526-non-ofe-members-trade-delta |
| [2021-01-24 05:56:15] |
| User208416 - Posts: 44 |
iam trying to use the buysell pressure code by crazybears but it failes with an error while compiling . any one knows what is wrong with the BuySellPressure2.cpp code ? -- Starting remote build of Custom Studies Source files: BuySellPressure2.cpp. 64-bit -- 21:47:06 Allow time for the server to compile the files and build the DLL. The remote build did not succeed. Result: BuySellPressure2.cpp: In function 'void scsf_BUYSELLPRESS2(SCStudyInterfaceRef)': BuySellPressure2.cpp:41:116: error: 'DAYS' was not declared in this scope 41 | SCDateTime NextSessionStart = sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.UpdateStartIndex - 1 ]) + 1*DAYS; | ^~~~ -- End of Build -- 21:47:10 |
| [2021-01-24 09:45:03] |
| Ackin - Posts: 1865 |
similar as "Bid Ask Volume Ratio" study what is wrong with the BuySellPressure2.cpp code
Required SCDateTime Changes for ACSILWorking with the SCDateTime Variables and Values |
