Date/Time: Tue, 11 Mar 2025 01:12:04 +0000
Move stops to price (Client side)
View Count: 461
[2022-04-21 19:45:47]
User900285 - Posts: 98
Is there a technical reason why Move Attached Stops to Price does not work with some client side attached stops?
An attached Bid/ask quantity triggered stop would be an example.
The keyboard shortcuts for Stop Order Tick Up/Down do work with this client side attached stop.
Would be nice to have the other command work too.
[2022-04-21 22:05:04]
Not sure. We would not expect this to be an issue. We will check.
[2022-04-21 22:29:46]
Sierra_Chart Engineering - Posts: 18738
We will implement a solution to this in the next release.
[2022-04-21 23:50:55]
Thank you.
There is something related to this order type that I would like to also share.
I found that the Bid/Ask Quantity Triggered Stop does not work correctly when testing in a market replay with historical market depth.
The order triggers off immediately as if it is not recognizing the market depth data being replayed on the chart.
The same happens with the study Trading: Bid/Ask Quantity Triggered Stop, in a market replay.
As a comparison, Traded Volume Triggered Stops do seem to work fine in a market replay with historical market depth.
