Date/Time: Tue, 11 Mar 2025 01:15:58 +0000
Hello Support Staff.
View Count: 470
[2022-04-21 19:09:56] |
Mr.DaxF - Posts: 45 |
it is possible to can have the CPP file from this study? also it is possible to explain how this study works? cause i dont find anything when i click the "discription" button in study setting on bottom to see discription of study! this will be nice when i can check the code to understand what the study is doing! thanks |
[2022-04-21 20:32:28] |
John - SC Support - Posts: 38547 |
What study are you referring to? In general, refer to the following information for how to find code that is available for the Sierra Chart studies: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Also, if this is a User Contributed Study, then code might be available here: User Contributed Advanced Custom Study System Source Code For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-04-21 20:57:16] |
oh sorry i forgot to share the indicator name: SierraChartStudies_64.scsf_MarketStructure and UserContributedStudies.scsf_SwingMarketStructure |
[2022-04-21 21:45:58] |
Refer to the information we gave previously. The code for scsf_MarketStructure is available in the file Studies7.cpp. The code for the User Contributed study we do not have. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
