Date/Time: Tue, 11 Mar 2025 01:12:57 +0000
Supertrend stop visual modification
View Count: 490
[2022-04-21 16:59:21]
SabikiSensei - Posts: 76
https://www.sierrachart.com/image.php?Image=1650560268976.png
Is there any way I can remove the vertical line when the super trend changes from blue to red and red to blue? (marked with arrows)
[2022-04-21 17:16:07]
John - SC Support - Posts: 38547
There is not a way to do it specifically when there is the transition from Blue to Red (and vice versa). You could change the Draw Style from Line to Dash which will remove the connecting lines between bars, but it may not be visually what you want either. Refer to the following:
Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH)
