Date/Time: Tue, 11 Mar 2025 01:12:14 +0000
Coloring Number bar values
View Count: 469
[2022-04-21 02:43:51] |
User447431 - Posts: 29 |
Im using the study "number bars calculated values" with delta, delta % and total volume I would like to color the delta and delta % with red/blue, and the total volume with grey/black Should I duplicate the study and use 1x study for delta and delta % and another study only for total volume (like picture 2 attached), how can I do that? If I need to use 2x studies number bars value theres a way to eliminate the space between these 2x studies? thanks |
[2022-04-21 14:41:10] |
John - SC Support - Posts: 38547 |
The only way to do what you want is to use the 2 instances of the study. But, there is not a way to eliminate the space. It looks like you have done everything to minimize it, but there will always be the equivalent of one line of text between the regions.
