Date/Time: Tue, 11 Mar 2025 00:51:46 +0000
Tools, Horz lines- Not linking from detached chart to others
View Count: 407
[2022-04-20 22:03:41] |
User624220 - Posts: 7 |
Using detached chart window, I cannot resolve following problem Have all charts linking set to same number- I add horizontal line to detached chart- will not show up in other charts. |
[2022-04-21 14:23:15] |
John - SC Support - Posts: 38547 |
We are not seeing any issue with the copy drawings functionality to Detached charts. The first thing we need to ensure is that you are using the correct method, as you use the word "linking". In order to copy drawings between charts you need to use the Copy Drawings option under Chart >> Chart Settings >> Chart Drawings >> Copy Chart Drawings From Chart #'s. Refer to the information here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Also, if the detached chart is a different symbol, then make sure you have the option for Show Chart Drawings for Different Symbols is set to Yes. Finally, refer to the following for other possible items: Chart Settings: What to Do If Chart Drawings Do Not Copy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
