Date/Time: Tue, 26 Nov 2024 09:42:49 +0000
CHART HEADER
View Count: 1235
[2014-04-24 20:05:13] |
User98345 - Posts: 16 |
i have a problem with the chart header.i have selected the daily net change and daily net change percent options.i see them on the header but they don't work.they are always zero.why is that? when i was with the TT FIX they worked just fine. with the CQG they don't work.am i doing something wrong? |
[2014-04-24 22:54:27] |
Could you please post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image We tested this, and we see the daily price change. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-25 04:19:06] |
http://www.sierrachart.com/image.php?l=1398399478754.png |
[2014-04-25 07:28:32] |
We are checking on this.
